**** Official Microsoft Flight Simulator Thread ****
Yeah. Should have thought about it before tbh because I already do it on work projects because it has a big impact on build times, reading so many small files. MSFS is similarly huge numbers of relatively small files.
Wow interesting, I'll give it a go. Cheers for the tip
When you say data directory do you mean the one in appdata?
Just ordered a 5800x, 32gb ram and a 1tb m.2 SSD to replace my aging 2500k, keeping my 980ti for now but aiming to replace that with a RTX3080 when I can so looking forward to seeing how much better it will run when it is all set up :)
Thrilled. Managed to snag a
Thrustmaster TCA Sidestick Airbus Edition.
Tried playing this with keyboard & mouse and a xbox gamepad. As pretty as this game looks I feel a flight stick is essential and I'm hoping now to play SW Squadrons now also (again was waiting on a good hotas deal) Had FS2020 since launch and probably oy played it about an hour if that. For me it's a bit like playing say Fifa on a keyboard instead of a gamepad. I hope its worth it and the cost was only £64 which I don't think is too bad considering how damn hard these are to find. Ive been fortunate as I have everything I intended to buy since September 2020. I do feel for those who are still waiting on components and I'm aware I'm a lucky boy right now.
Arrives tomorrow and am seriously looking forward as covid is making doing anything outside the home tough.
How well does this run on the Quest 2 and what is the image quality like, reading A320 displays for example ? I had to return my Reverb G2 due to a fault and am getting a refund because there is no stock. I'm considering a quest 2 and this is one of the main sims/games I play.
Is there anywhere that gives the best settings for the 3080?
JayzTwoCents did a decent video about Flight Sim settings and what can be reduced with minimal visual penalty.
However the 3080 should do mid 30s FPS with everything on ultra 4K and 1:1 resolution.
Personally I'm on an overclocked 3070 and run most things at 4K ultra but with things like bloom and DoF disabled, 1:1 resolution scaling, and detail settings for scenery and objects reduced from 200 to 150.
See here for some quest 2 vs rift s vs G2 impressions for msfs, for reference he is currently on a 1080Ti I believe.
Thanks for that, it looks more promising than I thought. I would go Index but I have a feeling there could be an update to that later this year given it's life cycle so a Quest 2 would tie me over until then.
I love this game but struggling with my X52 HOTAS; just seems to be off quite consistently veering off to the right; I've checked everything but think I'll need to accelerate getting it swapped.
I knew there was a couple of dodgy selections on the hat switch on the stick but able to work around for now (and I don't want to be without!)
Just heads up that there does appear to be stock of the more popular HOTAS/Joystick options appearing; must have been a shipment received somewhere - decided to "upgrade" to the Warthog HOTAS and send the X52 back
