How to install upper case fans ?
What case is it.....
But based on that image, it looks like it doesn't even have the screw holes for fans to be installed up the top...
Looks like a very close fit. For the sake of RGB probably not worth it. I'll just get an RGB ( controllable ) case fan at the rear.
It is a fractal design focus G full sized ATX..
https://www.fractal-design.com/products/cases/focus/focus-g/black/
According to the website I can have 2x120 or 2x140mm fans..
Here are the screws at the top
It will be able to take 2 fans, you'll just need to manage the wires (I'd probably go 2x120mm to give a little more room for cable routing) so they don't foul the blades etc. If it's for airflow silverstone did (and I assume still do... others might too) do a slimmer thickness fan which might be an option.
As to how to fit them it's literally put fans as close to the top of case, in alignment with the holes, then screw in from outside, just think carefully about cable runs.
I went for the Corsair iCUE SP120 Triple pack with lighting controller ( 120mm as you said )
I figured a way to get the fans in ( hopefully ) i'll slide them in from right to left and then screw them in from the very top of the case
Installed the three fans...
Installation was easy. One of the fans sllightly covers one of the RAM latches that you clip open and closed but very happy
