As Farex said, psu looks like weak point in the build, particularly if you get navi/ampere at some point. I know stock is low and its not budget Kolink, but I would be suspicious of lower grade capacitors etc. that can cause problems over time.Are there any weak points or poor choices here?
Review of that very psu.... better than expected, and I rate KitGuru
https://www.kitguru.net/components/...continuum-850w-platinum-modular-psu-review/6/
