Are Nvidia again selling them direct in the UK or have they still outsourced it to S***?
What clocks are you guys getting out of the box with the 3090FE?
I'm on 1965MHz GPU
9751MHz on the memory
Idle looking at GPU 210MHz
Memory 405MHz.
I think my old 1080Ti extreme used to boost to about 2060 out of the box, obviously a completely different architecture.
I've been looking at a few YouTube videos on undervolting.
Sounds pretty beneficial however I was wondering how they undervolt and over lock or do people generally just undervolt the 3080?
To me it's nuts that people are paying over double the price for like 10% or so over the 3080 just because of availability. It's very suspect that the 3080 rarely comes into stock yet the higher priced card shows up almost like clockwork be it FE or AIB.
I think both amd and nvidia are playing it "cute" this time around with availability of these cards, just a little trickle now and then to keep the baying hounds appeased. Though AMD might need to get their their trickle checked by a Dr as it hasn't existed since last year.
If you are using VR and want to maintain 90hz, then the extra 10/15/20% performance makes all the difference...
And I think if Nvidia could have the shelves full of RTX3000 series cards, they would, why would they want to cripple their business?
Can do both. The stock voltage profile is very heavy handed I found. my normal profiles for daily use undervolt and overclock (compared to stock). Do note however if needed, such as heavy benchmarking or RT games, the card will still draw on max power. Really a matter of messing with it and is a good way of learning the chips behaviour at various voltage points IMO.
Thanks, I've only ever done undervolting on a 1070 laptop with some good success so interested to learn how to OC also.
How do you go about discovering the max memory speed and core speeds? Just edgge it up a little at a time? Any videos you can recommend to watch?
I'm coming from an AMD card so not used Afterburner much.
Yep, increase it in small increments, test, then increase, test, etc, until you see performance drop, then go down a notch.
All the difference at over double the cost, not exactly an enticing proposition.
I'm in VR with a G1 Reverb. I think I can get 10% more performance by turning down one setting, one notch.
But you can't run SS at 100%, ultra/high detail. I don't want to turn down settings...
Nvidia have confirmed it now.Rumors say 3060 (non-Ti) will not get Founders Edition.![]()
As for stock, it wouldn't surprise me if the fe cards are made an sold at a loss as they're put together better than just about any of their aib partners. There's not a single aib card i can look at and think it looks better made than what nvidia are doing at substantially lower cost, and if aib's can't get to a similar quality level at a higher price then nvidia must be taking a hit on selling the FE cards for what they are. So if that's the case (and i'm not saying it is) it makes sense to make them scare and phase them out pretty quickly.
The 3090FE is easy to get, you dont need an alert, just watch this thread. Theyre usually up for a few hours before selling out.
