Hello folks.
So I purchased an AX1800 TP Link router with a view of using this with my Oculus Quest 2 only.
Ideally Id like it to also access the internet and herein is my problem.
I have two ethernet ports on my PC, one is connected to the TP Link (used as Access Point for the Quest 2 only).
And the other ethernet port is plugged into a Superhub 2 cable connection.
How can I get my TP Link router/access point to use the internet off the other ethernet port?
Or must I connect the TP Link into the Superhub 2 as well?
Thanks folks.
Thanks folks.
