Hi all,
I am having trouble getting Precision Boost - Boost Clock Override to work. I have set the core clock override to +5MHz, +200MHz and even +300MHz but nothing seems to have an effect. I also tried setting the scalar to 10x, EDT/PPT/TDC to 'Motherboard', manually tweaking them and also tried tweaking curve optimiser. No matter what I try, the clock will never boost over the factory 4.9GHz single-thread (testing with Cinebench R23). It also has no effect on multi-thread testing. I also do not appear to go above 5.0GHz, at all, during any test (I know some people do even on stock).
I should note separately that setting PBO to Motherboard does have an effect and multi-threaded clocks jump to around 4.4GHz and Cinebench scores increase substantially.
I should also point out that I have absolutely no trouble exceeding factory clock speeds by manually overclocking, it's just the PBO clock boost that does not appear to work.
I am also running on a custom water cool loop and temperatures are fine. With PBO enabled I am not exceeding 60C single-thread and 77C multi-thread.
I currently have a Gigabyte Aorus Master X570 with F31 BIOS. I am aware that PBO2 is not supported until AGESA 1.1.8.0 but apparently the Master mobo has the necessary code to make it work (PBO2 is indeed listed in settings).
Anyway, why the heck can I not get my CPU to clock anymore than factory when using PBO clock boost? It's driving me nuts...
Thanks,
Thanks,
