@WJA96 - I've been having a play with my USG as I've had a few days off work. I've been experimenting with the LAN2 port. In the controller I have set up a new LAN2 network (Purpose: Corporate, Network Group: LAN2) with Gateway IP/Subnet: 192.168.10.1/24 and a DHCP range of 192.168.10.6 to 192.168.10.254. My LAN1 network is 192.168.1.1/24 with a DHCP range of 192.168.1.6 to 192.168.1.254. However, the clients I have connected to the LAN2 port (via a switch) still have IP addresses of 192.168.1.x, despite me clearing the DHCP leases and rebooting the USG. What am I doing wrong? I haven't set any bridging rule, so it can't be that it's seeing LAN2 as part of LAN1, can it?
What IP address is the switch getting, and is it managed or dumb?
In the USG in the controller set LAN2 to your new network.
Yes, if you made a backup of the controller setting before you changed everything. You can just roll back to that point.
Ir you could just allocate fixed IP addresses (with reservations) to your Sky devices so they are all on the same subnet.
I don't think I need to roll the controller back, I can simply not use the LAN2 port, right?
As for allocating fixed IP addresses to all the Sky devices, can I assign a 192.168.1.x address to a device physically attached to a (dumb) switch attached to the LAN2 port, therefore on the 192.168.10.x subnet?
By the way, thanks for your continued help!
Yes, you can just stop using LAN2.
And yes, you can give a device on the 192.168.10.x subnet an IP address of 192.168.1.x and it will show up on the other subnet. The router only sends traffic out to the clients. If it sees your client it will happily deliver and receive traffic from it. If not, it won’t.
If Crosstalk Solutions and Lawrence Systems have changed their tune on Protect I’d be very surprised. They both got badly burned when UBNT switched off Unifi Video and the last video I saw from both suggested doing something other than Protect. Lawrence especially have several videos featuring both Dahua NVRs and Synology NVRs.
Ubiquiti have a very nasty habit of just stopping entire product ranges and dropping support for them. I know people who bought USG-XG-8’s on Monday and they were EoL’d on Tuesday. They obviously sent them back but if you were not within the return window you’re absolutely screwed. And that’s precisely what UBNT did the their camera users. The old UNVR products are now basically paperweights.
And on the switches, no. You wouldn’t see any real benefit.
There are a number of issues with the controller at the moment -most prominently the fact that disabling or changing a feature in one interface doesn’t necessarily mean it’s turned off in the other so it stays on. This can be seen in the disable WiFi optimisation setting where you have to turn it off twice to keep it turned off. I suspect you’ve fallen foul of one of these issues and something is sneakily reasserting itself in the other interface.
