- 6 Jan 2011
- Stoke on Trent
Is there anything out there which will give me a worth while upgrade. I mainly use for gaming Iracing is one of my main uses which is vey single core heavy. Also VR. I notice the AMD offerings are pushing these speeds nealy at stock, or is this just a boost for short moments? If I can run 4.8 or 4.9 on a new chip then surly the IPC gains will trump my 8700k all cores at 5ghz?
All the research just gives a lot of information on like for like, but not that helpful comparing against my set up scenario. Mainly because it is unclear if those speeds are maintained and against how many cores. I`m guessing people are gona say don`t bother at the moment?
Just to add running 3080 and a revertb G2 so want to push as much performance as I can for this goodness.
