The issue I was having was one in which my A7 display reads bulb indicating an exposure of over 30 seconds is required but fails to indicate the length of exposure- which in a scene consisting of next to no light could be anything plus the time it takes to process. Once you need to go above 2 minutes it becomes a pain.
I suppose the other way to do this would be to take the exposure when there still remains a little bit of light to work with. However some Olympus cameras have a function called live bulb mode but the Sony doesn't making things a little harder.
I don't know if this will help you but I taught myself about long exposure times a few weeks ago. Basically keep increasing the ISO until the exposure meter is correct, then once you know how long the exposure should be, put the ISO back to 100 and then take the picture.
Below I've pasted my own words that I wrote into my photography notes on my phone to remind myself how it works. Then based on those notes I calculated bulb exposure times for every ISO and wrote out my own cheat sheet which will save me having to calculate when I'm actually out and set up with the camera on a tripod. I don't know about with ND filters, so these calculations are mostly for night time with no filter. I hope my notes below make sense
MY NOTES
'To calculate exposures longer than 30 seconds (mostly at night) so that the photo is not under or overexposed:-
Set 1SO to 100 and shutter speed to 30 seconds. It should be underexposed at this point. For each full stop of ISO I increase by, double the shutter time.
So 200 iso is 1 full stop and is doubled from 30 secs to 1 minute. 400 iso is 2 stops and doubles from 1 minute to 2 minutes. 800 iso is 3 stops and doubles from 2 minutes to 4 minutes. 1600 iso is 4 stops and doubles to 8 minutes. 3200 iso is 5 stops and doubles to 16 minutes, etc.
So if for example my exposure meter was correct at 3 stops (iso 800), I'd set bulb timer to 4 minutes. I'd then bring the ISO back down to 100 before starting the 4 minute exposure.
For thirds of a stop, take the difference between stops and divide by 3. So for example, the difference between 400 and 800 iso is 4 minutes minus 2 minutes = 2 minutes.
2 minutes × 60 = 120 seconds.
120 seconds ÷ 3 = 40 seconds.
So 2 and a third stops is 2 min 40.'
My ISO CHART BULB TIMES
100 - 30 secs
125 - 40 secs
160 - 50 secs
One stop and thirds
200 - 1 minute
250 - 1 min 20 secs
320 - 1 min 40 secs
Two stops and thirds
400 - 2 minute
500 - 2 mins 40 secs
640 - 3 mins 20 secs
Three stops and thirds
800 - 4 minutes
1000 - 5 min 20 secs
1250 - 6 min 40 secs
Four stops and thirds
1600 - 8 minutes
2000 - 10 min 40 secs
2500 - 13 min 20 secs
Five stops and thirds
3200 - 16 minutes
4000 - 21 min 20 secs
5000 - 26 min 40 secs
Six stops and thirds
6400 - 32 minutes
8000 - 42 mins 40 secs
10,000 - 53 mins 20 secs
Seven stops
12,500 - 64 minutes
That only applies to film as digital has a linear response to exposure. In a film data sheet, there is a always a section on it and the necessary corrections that need to be applied depending on the metered exposure time.Also reciprocity law failure to think about.
Wow, did not know that. Shows I'm old school taughtThat only applies to film as digital has a linear response to exposure. In a film data sheet, there is a always a section on it and the necessary corrections that need to be applied depending on the metered exposure time.
MY NOTES
100 - 30 secs
125 - 40 secs
160 - 50 secs
One stop and thirds
200 - 1 minute
250 - 1 min 20 secs
320 - 1 min 40 secs
400 - 2 minute
800 - 4 minutes
1600 - 8 minutes
3200 - 16 minutes
6400 - 32 minutes
Seven stops
12,500 - 64 minutes
Checkout this 8 minute exposure with some funky stuff going on I can't scientifically explain. I was experimenting with a 10stop ND plus CPL.
With the Nikon D610 being an old camera I had to remote expose the image using an app by a live USB feed.
