- 19 Jan 2006
Just curious whether any of you have had any experience with the 17mm thick copper radiators which are available through AliExpress? https://www.aliexpress.com/item/1005001355572417.html?spm=a2g0s.9042311.0.0.591d4c4doDGu4k
They come in at around £45 delivered, but the fact that they're 3.5mm thinner than the XSPC slim rads makes them quite intriguing to me! I've ordered one, along with one of the Barrow integrated waterblock/pump/reservoirs and intend to create a dual 240mm radiator setup in a Streacom DA2, slotting this rad underneath a watercooled 3080, with a couple of Noctua 120x15mm fans.
I know some have said that because they use circular heat pipes rather than flatter squarer ones they don't have the same surface area / heat dissipation of more premium radiators but I do think coupled alongside a "good" 240mm radiator I should be seeing decent temps and low noise in a very compact system.
