8 Pack 3600MHz CL16 - DOCP profile request
18 May 2010
London
I have the 3200MHz version of the 8 pack ram but the 3200MHz and 3600MHz CL16 stuff are the same bin.
I'm having memory issues at present since installing my 3080.
Is someone able to take a screenshot of the DOCP/XMP timings of the CL16 kit for me so I can try it please?
Set the DOCP/XMP profile and then go to your full timings section and take a screen shot of the primary and secondary timings if possible.
Or even better extract the timings with Typhon burner and upload it somewhere for me to download.
Would be greatly appreciated.
Thanks
MEMORY MODULE
MANUFACTURER
Team Group
SERIES
Not determined
PART NUMBER
TEAMGROUP-UD4-3600
SERIAL NUMBER
01046107h
JEDEC DIMM LABEL
8GB 1Rx8 PC4-2400R-UA2-11
ARCHITECTURE
DDR4 SDRAM UDIMM
SPEED GRADE
DDR4-2400R
CAPACITY
8 GB (8 components)
ORGANIZATION
1024M x64 (1 rank)
REGISTER MODEL
N/A
MANUFACTURING DATE
August 12-16 / Week 33, 2019
MANUFACTURING LOCATION
Taiwan
REVISION / RAW CARD
FF00h / A2 (8 layers)
DRAM COMPONENTS
MANUFACTURER
Samsung
PART NUMBER
K4A8G085WB-BCPB
PACKAGE
Standard Monolithic 78-ball FBGA
DIE DENSITY / COUNT
8 Gb B-die (Boltzmann / 20 nm) / 1 die
COMPOSITION
1024Mb x8 (64Mb x8 x 16 banks)
INPUT CLOCK FREQUENCY
1200 MHz (0.833 ns)
MINIMUM TIMING DELAYS
16-16-16-39-55
READ LATENCIES SUPPORTED
18T, 17T, 16T, 15T, 14T, 13T, 12T...
SUPPLY VOLTAGE
1.20 V
XMP CERTIFIED
1799 MHz / 16-16-16-36-53 / 1.35 V
XMP EXTREME
Not programmed
SPD REVISION
1.1 / September 2015
XMP REVISION
2.0 / December 2013
FREQUENCY CAS RCD RP RAS RC FAW RRDS RRDL WR WTRS
1200 MHz 18 16 16 39 55 26 4 6 18 3
1200 MHz 17 16 16 39 55 26 4 6 18 3
1200 MHz 16 16 16 39 55 26 4 6 18 3
1067 MHz 15 15 15 35 49 23 4 6 16 3
933 MHz 14 13 13 30 43 20 4 5 14 3
933 MHz 13 13 13 30 43 20 4 5 14 3
800 MHz 12 11 11 26 37 17 3 4 12 2
800 MHz 11 11 11 26 37 17 3 4 12 2
667 MHz 10 9 9 22 31 14 3 4 10 2
1799 MHz 16 16 16 36 53 54 13 13
Dunno if this helps
What I am looking for is the timings so I can copy them and stick them in to my bios.
I have the 3200mhz ram bit it is the same bin as the 3600 cl16 stuff. I just don't have a docp profile for 3600 cl16 on the ram.
A typoon burner profile would be ideal.
Out of interest what memory issues are you seeing since the 3080 upgrade?
The reason I ask is that I upgraded from a 1080 to 2080ti and had memory issues causing CTD, turns out the modules were faulty. I never had any issues when the 1080 was installed though, very odd.
If you loosen the timings does the issue go away?
Well I ran my ram at 2133MHz yesterday and it seemed ok.
Thanks for giving me the typhoon burner dump, however I was hoping this would reveal to me the timings in the dram calc but it doesn't.
If it's possible are you able to set the docp profile of the the 3600cl 16 ram and then give me the timings?
If it's too much trouble or will mess up any of your bios settings don't worry about it.
As my ram is the same bin as the cl16 3600 stuff I am just trying to replicate the docp settings.
try the 3200 xmp settings
I can do. Thing is I got used to running them at 3600MHz and can't accept anything less. Especially when AMD have said that 360MHz is the sweet spot.
The ram can run 3600MHz all day long. It just makes me feel better if I was using a docp profile which I don't have.
