can you buy one from ocuk at msrp? sure you can get them retail if you want to spend all day watching feeds etc whos got time for that? you guys all deflecting from the point, where you can get a 3090 at infalted prices 1800+ its not worth it as theres single digits in it. even at mrsp is it worth it? defend what you want but all of the tech press disagrees with you and most of the tech industry follows those guys. allot of the people who brought the 3090 in that thread likely did so before the 6900 came along which makes sense, or are die hard nvidia only people. you cant present facts and figures to people who dont want to believe the truth.![]()
i'm defecting from a 3090 to a 6900xt, the games i play there is little to no diffrence between the 2, most games i play max out the frame buffer at 12-13gb so for the 3090 the extra 11gb or so is doing nothing, sure its nice having all that performance but the power requirments for me are just too high now, 380-411w just for the card is stupid when the 6900xt can run 250-320w for almost the same performance, and i'd be using more of the amd card vs the 3090 i have.
the problem for me is the 3090 fe is always hitting power limit which makes the card downclock is some instances to it boost of 1770mhz or so which at 4k does hurt the cards performance, thats with a waterblock attached, i'd rater take on amd's offerings and get lower power draw and almost same performance as the 3090
