got my 980 Pro.
Pity you couldn't get a SN850 - I've heard it smashes the 980 Pro!
got my 980 Pro.
At twice the price of the sn750 I couldn't justify it. Got the 750 for now.Pity you couldn't get a SN850 - I've heard it smashes the 980 Pro!
And it smashes your wallet![]()
The 970 Evo Plus is loltastic at its current pricing, almost as much as a 980 Pro or sn850. Who is buying those...
Samsung still pricing their units like they have no competition, when actually they do..
but I haven't looked much into it since I really gotta first secure the CPU/MB/RAM at least, in the next few months.Tempted to get a sn850 1tb for my new gaming build next year. I only ever have a few games installed at a time thanks to a fast internet speed and i can only keep track of playing 2 games at at time lol.
Where are people finding 980 Pros (1TB), nowhere seems to have stock?!
How expensive was that?Worth waiting for the heatsink version of the WD 850 2tb? Or will a motherboard heatsink be fine? MSI Unify X motherboard.
Edit: found it available so ordered it.... yolo!
£450.How expensive was that?![]()
Was this via eBay? I think you mentioned this on discordJust upgraded my main to a 2TB SN850, brought it for pretty cheap. Now I can install all the games in my library without worrying about space.
You know it mateWas this via eBay? I think you mentioned this on discord
Think I’ve having Brexit related delivery issues at the mo... still nowhere on site![]()
Awesome! Glad it worked out for you.You know it mate
I just did a clone from my old drive to this drive and it is working all as it should be.
I’ve just noticed that my motherboard has an m2 plate so the heatsink version might not fit... time will tel ><
Think I will be ok with the GPU but you’re right that the plate is probably detachable... the manual is confusing on the point unfortunately. Next week will be the moment of truth... if the dang thing arrives!!Its more of the GPU clearance you need to worry about I thinks. If the motherboard m.2 plate is removable and if it isn't interconnected to other bits of the motherboard , then you should be good to go.
