I've had my current gaming PC for around 5 years now, and it's getting time to upgrade. My current PC specs are as follows:
Current PC Specs: https://i.ibb.co/fnPJ5QD/Untitled.png
My power Supply is a "Corsair VS650 650 W Active PFC 80 PLUS Certified Power Supply Unit". It is around 6 months old.
My question is, what can I keep in the PC and NOT upgrade? I'm trying to save as much money as possible, so if there's anything I don't need to upgrade then I'd appreciate knowing. The following is what I WILL be upgrading to though:
Would I be okay sticking with the storage drives I already have, or do you think they'll need upgrading too? I'm actually not sure if getting a more up to date SSD will improve performance in my new PC, or whether I'm okay sticking with the SSD I already have. Whilst not the biggest size, the space of my current SSD is more than enough for what I use the PC for, as I only ever have 1-2 games installed at a time. I'm also not sure if my current Power Supply is powerful enough for the new hardware I'm planning on getting.
Thank you very much.
- GPU: Nvidia RTX 3060 ti
- CPU: Intel i7 9700K
- Motherboard: MSI Z390-A PRO ATX, LGA1151
- RAM: Corsair Vengeance RGB PRO Black 32GB 3200 MHz DDR4 Dual Channel Memory Kit
- Monitor: Not sure yet, but will be a 1440p Monitor for sure, so I can upgrade from 1080p.
