How do you measure the 30XX memory temp?Wouldnt worry about the gpu temps, it's the memory you gotta watch and those Fe cards are pretty bad with that!
Just transplanted my build in a P500a. Amazing case, such a easy case to build in.
3080FE idle temp is now 28c with 3x140mm intake fans and 3x140mm exhaust fans at 400rpm.
Has even knocked 5c off my 5800x to idle of around 32c.
Idle currently sitting at a quite chilly 21c
Not sure why everyone things the 30XX FE card run hot. This is the coolest GPU i've ever owned! (Well, maybe not the Matrox Mystique 220!)
