- 30 Sep 2006
- Midlands, UK
Hi all,
thinking of getting into this 3d printing malarky.
As a project (and waaay overkill) would it be possible for a 3d printer to accurately print out a rectangle say 200mm x 80mm x 12mm thick with a cutout in the centre measuring 26mm x 57mm?
Would the edges of the cutout be perfectly straight? Or would it depend on printer resolution and type of material used?
Basically i want to create some cutout templates for when i'm putting hinges and latches onto doors. They would be used as guides for my router and would sit inside a wooden frame that i'd make myself. So interchangeable 3d printed templates depending on size of latch/hinge i'm using.
I've made my own wooden ones which work fine, but i'm interested to see if it can be done and would go a way into convincing me to buy a 3d printer for other projects too.
If anyone would be willing to have a crack at doing one for me, i'd be willing to pay for it. It's the interest more than the cost (as long as its not crazy money).
Cheers
Cheers
