- 19 Jan 2021
Fans are noticeably loud, despite the temps for CPU/GPU being low. Had a quiet preset in bios which thought would solve, however even after a custom curve reducing them to 20% up to 50C they run loud :/ Not sure why this would be. They are Thermaltake fans tt-1225 that come in the pure 12 argb sync triple packs, they are marketed as pwm 500-1500 rpm fans. 25.8db
The other thing is they came with 3 way fan splitters, looking at the pin outs it seems there is 1x 4 pin and 2 x 3 pin for the splitter, going to a fan header. I assume this is for the rpm feedback?
When I use my hand to check the 3 on the same splitter feel like they are moving different amounts of air, despite being right next to each other. Anyone come across that before??
