What weight can breeze blocks support?
6 Jan 2006
Newcastle upon Tyne
I probably shouldn't worry about this but being a bit of a control freak I was wondering what weight breeze blocks can support? At the initial stages of a conversion and the builder has said the steel beams are over 1 tonne in weight which seems a huge amount of weight to me?! There are 3 beams in total and they'll be connected in an I shape with the ends of the "I" being supported at each end (if that makes sense). The house is 20 year old with block and brick construction but will the block work support 1+ tonne?! The calcs have been done by a qualified surveyor so I assume he is aware of the load etc but it just seems a staggering amount of weight to add on but could well be the norm?
Well I’m worried that my house will collapse or the beams will fall and crush my children! Being serious and slightly less dramatic though I’m more interested in if that weight is typical for an extension/conversion? As I said in the OP it seems a staggering amount of weight but I guess it is holding up the house!
1 tonne isn't all that much, I've got 5 steels in my kitchen extension, 3 of which are > 1 tonne and the existing structure is is fine. You've paid an expert ot calculate this stuff. Relax.
An entire roof load tends to be transferred down the inner skin of your home, so yes blockwork is designed to handle large loadings. Also the concrete padstones that the builder installs at the end of the beams help to transfer loads too. Don't worry about it at all, if your extension is being signed off by building control then the steel calcs will have been submitted by the surveyor.
If I recall from some this old house episodes it depends on what the breeze block is made up with regards to the mix as then its rated in psi. Between 1000 and 5000psi depending on the mix when formed. 1 tonne will be spread among a number of the bricks to disperse the load so even at 1000psi they are more than strong enough to support them. You cannot convert directly from tonne to psi as would need to know the load area. That's from my understanding could be nonsense though hah :D
As long as a structural engineer calculates it, will be fine. The underside of each beam will have a padstone and packed up with slate or steel packing and grouted.
Correct, the padstone will also be sized accordingly to make sure the weight is distributed over a larger surface area of the block work, rather than a point load (if the engineer has done their job properly).
This
Make sure builder uses pad stones,keep an eye on this stage of the build :)
Even a rubbish block will support a tonne per square inch of area that the load is applied to. The beam load here will be distributed over many hundred square inches.
In a word, yes. Breeze block will support around 3/4 of a ton per sq inch, so the average breeze block, just one can support many times more than the load you are placing on them.
It's pretty scary when you know how much weight is above your head but truth is that even a normal roof would squish you absolutely flat if it failed yet it is only supported by some rather flimsy looking timbers.
The actual load on the beams will be more that their own weight so it will be taking far more than the dead load of the beam. Don't forget though that load transfer is divided down the middle with half the load going to one end and the other load to the other end (crudely). Load transfer down the wall dissipates out at 45 degrees from the pad stone and within a few courses it's reduced significantly.
Ultimately if you've had it designed by a SE then relax.
Thanks all for the advice and reassurance, guess I just heard the weight and thought it was a massive amount that was being added! Having thought about it further I also have the reassurance of the building inspector who seems very proactive (having been out 3 times already to see when the work is starting) who I assume will check the padstones etc have been correctly spec'd and installed.
There's not really any such thing as breeze blocks any more, there's several types of blockwork all with differing capabilities of load.
If a beam is one tonne that's half on each end plus whatever it's supporting. There should be a structural calculation available if you're worried backed up by professional indemnity insurance. There are standard calculations that can be used but very very rarely does everything line up and meet a standard calculation.
Structural engineer here. How long is the beam? Frankly a domestic steel beam being 1T sounds ridiculous. Even at 10m long, which in itself is quite a lengthbof opening to span, its 100kg/m and that size beam must be holding up a storey or two of masonry and floor! I doubt I've specified beams heavier than 50-60 kg/m,mainly on a h&s/practicality of lifting viewpoint.
To your specific question, it depends, maomsry blocks come in 3.6,7,10,20 N/mm2 strength. Padstones are as strong as concrete.
At the end of the day, as long as a professionally qualified structural engineer has been employed to do the maths, you can sleep easy. If your "surveyor" has just gone a selected a beam, then I would worry. Have you had Building Control approve the drawings/calculations or inspected the works? Again that size beam suggests to me it's a substantial bitnof work being undertaken.
Thanks for the reply, the work being carried out isnt that much in my humble opinion (although Im not a builder, clearly!) The kitchen is being extended into the utility room and about 2m's of the garage. Bit of an odd layout currently but I'll end up with a rectangular room 8x4m ish.
The wall is being knocked down between the kitchen and utility room which supports the gable end and 2 x 4.2m beams (bolted together side by side) are being installed. These are relatively light as Ive lifted the ends to make some room in the garage.
The beam which the builder said was a tonne is a 6.3m steel which is being installed from the 2 beams mentioned above which will allow for the wall to be knocked down into the garage. The thing I dont understand is that there is nothing above this part, the utility room is a flat roof and the garage has a pitched roof. Appreciated that pitched roof will have a decent weight to it but its not a 3 story town house thats for sure! Ive not seen this beam yet as was meant to get it on Monday but didnt because of the snow.
There there is a lintel being installed for patio doors at the other end of the long steel. The lintel seems huge too!
Obviously it could be the builder making a meal of it and making the job sound more complex etc but he will have to make 3 trips (already made 2) for the steel because of the weight on his truck (which was a Merc Sprinter drop side by the looks of it). He said the large beam has a 400mm plate on the bottom to support the celling joists which is adding to the weight.
The building inspector has seen the plans I believe, as I emailed the building control a copy when I paid the fee etc. Ive got his mobile so I could always give him a call I guess although just not sure if I am worrying too much and should just let them crack on.
Structural engineer is qualified and insured to the best of my knowledge.
Sounds legit then. And fair enough if it is plated to support joists, it will be heavy. Though still maybe a bit of an exaggeration by the builder.
A **** ton is the correct answer.
Are you sure they are breeze blocks (i.e. airecrete) or are they solid dense concrete blocks?
FYI, I'm in the middle of an extension - you can see the rebuilt pillar and steel beams here - all done as per engineers calcs - it's holding up two stories (loft conversion done 18 months ago):-
@amigafan2003 those 2 beams that have been installed look to be exactly the same as the 2 in my garage and even look to have the same hole configuration drilled in. My "concern" was with the steel that Ive not seen yet but all seems to be correct and Im worrying about nothing.
I assumed they were "breezeblocks" but Ive probably just got the name mixed up. House has been built about 25 years and the blocks look similar to the ones in your photo.
