- 18 May 2010
Hi all,
My current setup is a docked laptop and my gaming PC connected to two monitors, I am looking to reduce clutter, gain space and heavily reduce cables so I was thinking of getting an Ultra Wide monitor to display two separate screens from my work laptop whilst docked and also take a connection from my gaming PC.
Because it will be for gaming I would like a high refresh rate no less than 144hz, low response times and for it to be able to take a connection from my gaming PC. Where it get complicated and I'm struggling to understand is how do I use a single UW monitor to display two separate images from my work laptop? I want it to act as if its two separate screens which I think is possible but I'm not sure.
Also I've read loads about reducing cable clutter by using your monitor to power your laptop through USB-C but again it gets a bit complicated, my laptop is a few years old but it has a USB-C connection with a little power symbol next to it, does this mean if the monitor has USB-C I can power my laptop from the monitor and output the image from the same cable? If so that would be a huge help in regards to cable clutter.
Is there anything I am missing when considering this setup, any tips or recommendations for monitors please? My budget is pretty open at this point, I want a minimum clutter, single screen setup and UW is the way to go to achieve this but the finer points are confusing me and I want to make sure I buy the right thing that'll do everything I need it to.
Thanks
Thanks
