Double slot pci blanking plate
22 May 2010
Minibotpc
Anyone know where i can get one of these? Been searching high and low and can only find the single slot ones.
Cheers
Need to modify it for passthrough, a single slot isn't tall enough. Tried with a single already and you end up taking away too much material making it basically useless.
Can you actually get a dual slot i cant find any results , maybe get somone to tack weld. Get somone to 3d print you one.
I assumed you could, maybe from older machines like Dells and HP's but cant seem to find anything.
Did think 3D printed would be my next choice but dont know if it would be strong enough to hold it. Any advice?
Not sure if a 3d one would be strong enough depends on how much rigid strength, other oprion is to try and make one out of metal or get one made.
Not sure if a 3d one would be strong enough depends on how much rigid strength, other option is to try and make one out of metal or get one made.
something like this would be rather expensive to make wouldn't it? Can't even find a similar thing to it so i could get the dimensions from it, something so simple yet so hard to find.
Ive asked in the 3D printer section for help, see if anyone can make me one. Only needs to hold the tubing in place, doesn't need to be particularly strong.
The only other option i can think of is an old dual slot graphics card plate but obviosly the input cut outs would be off
Found this but your gonna have to search to get it.
BITSPOWER DUAL PCI BRACKET
https://www.overclockers.co.uk/bitspower-dual-pci-bracket-bp-dualpci-wc-014-bp.html
