- 6 Jan 2013
- Rollergirl
Nor is your post even if his monitor is 60HZ 50FPS will seem laggy on a LCD in many games as does 90FPS in COD-BOCW for some reason.
You miss the point; if the refresh is the same at every resolution then the CPU load is the same. There's nothing special from a CPU point of view about 4k versus 1080p if they are both at 60Hz.
Appreciate that, but I couldn’t notice the difference between 60-80, hence why I limit it for games that target 60Hz instead. It’s not worth the extra watts/heat if I can’t notice the difference.
Fair enough, it's all about personal preference. I've had gsync monitors for years and if it's below 70fps then I can tell without the use of a frame indicator. I couldn't bear 57fps, but that's just me for some reason.
