New PC build complete
18 Nov 2020
Pictures don't really do the case/parts justice. Looks fantastic (to me anyway) in the flesh.
Could do with perhaps custom motherboard/gpu/cpu cables but I've tried to keep visible cables to a minimum.
Never done an RGB build before so i'm happy with how it's turned out.
https://i.~ibb.co~/ThSJ6Ly/20210210-141705.jpg
https://i.~ibb.co~/X25jB66/20210209-145404.jpg
Very nice .
Think i would rotate the cpu block 180 degrees and sort of route the aio pipes .
So have the pipes going along the back end of the case effectively?
Only issue with that is the castle360rgb AIO has very long pipes so the other way around pushes down onto the top of the GPU.
Nice clean build. What are the specs?
Mobo - MSI mag x570 tomahawk
Ram - 4x8gb Corsair Dominator Platinum RGB 3200mhz AMD Ryzen Tuned CAS16
CPU - Ryzen 7 5800x @4.7ghz overlock (1.3v)
GPU - MBA Saphire Radeon 6800
AIO - Deepcool Castle360RGB Version 2
Case fans - Deepcool CF120 Plus MB Controlled 3-pack 120mm A-RGB
Case - Lian Li 011 Dynamic Midi Tower - Black
GPU Support - deepcool gh-01 a-rgb
PSU - 850W Seasonic Focus GX 850 80PLUS Gold
HDD - M.2 Gen3x4 - XPG SX8200 Pro 1tb
