- 1 Jan 2003
- Derbyshire
Are you following proper procedure when putting the mounting screws back in? You should be putting two in at diagonally opposing corners and tightening them just a little, then adding the other two screws and then slowly tightening each one bit by bit on opposing corners to ensure even contact. If you just stick one screw back in and tighten it all the way, then move onto the next, or put two in on the same edge and tighten both down, it's going to cause uneven pressure and make the thermal paste spread out unevenly.To me, it appeared that the paste was missing on the top/right-hand side of the die?
is there something wrong with the paste? am I doing something wrong?
That would make more sense to me rather than the paste is bad. Comparing the card to ther EVGA 1080Ti SC2's I cant see anything out-of-place - The pads seem to be in the normal places (a picture from overclock3d.net);
If the cooler wasnt sitting correctly, that would explain a lot. I have never removed the base-place. The pad on the far right did tear in half once, but I put it back on (should be okay?). I did notice there is a screw directly right of the die, but that doesnt appear to be sticking up? The cooler has 3 cables (2 for fans, 1 for lighting) which get replugged in each time, im pretty sure none of those cables are trapped.
ps. here's how the cooler looks after cleaning;
[update] Ive been spent this morning looking at the pictures to see if I could see anything making the cooler not sit correctly. I was looking to the right of the card (towards the power connectors). Couldnt really see anything.. maybe the led cables... but there is a cut-out for those cables. None of the pads look wrong to me.
The heatsink fin you said about doesnt look as bad in the picture with MX4 on, could it be the flash on the camera?
I started to wonder if the paste was being pushed to the right, like the cooler isnt sitting correctly on the left (towards the bracket). The only thing I could see was some pads under the base-plate;
Would these be enough to make the cooler sit poorly? I guess they should be on-top of the memory chips, but they do look like they are nearly on-top of something else.
Does removing the base-plate mean removal of the back-plate too?
I dont have a clue, to me nothing looks majorly wrong.
[Update] Today I took some pictures of the card assembled;
It does appear to be a slight sag, it looks worse in the pictures (when you draw a straight line, it doesnt seem as bad). The card is installed vertical nowadays, so hopefully sag wont be so bad.
phew, I thought it might of been something leaking. Glad its normal due to the pads, and not the AIO.So are you back up and running? Good temps and clocks?
The oily marks on the pcb, are from the thermal pads and are quite harmless and normal. As with any cleaning of components, take care not to damage anything. Somethings don't need doing just for the sake of it, especially if it risks damage. I've heard of plenty of people that have 'knocked' components off trying to clean stuff.
What would cause cracked solder joints? Ive had the card from new, and it was brought here.the pressure between heat sink and gpu chip is uneven. Thus thermal paste. Were the pressure is strongest thermal paste gets squeezed out. look at both times its similar pattern. reading your issues i think you have cracked soldering joints under gpu. if im correct your best bet would be to reflow gpu chip.
Would I be looking for something proud on the left or right side of the die? the thermal pads on the card are the orignal. If something is proud, how much of a height am I looking for? 1mm? 0.5mm?You need to try and figure out why this is happening. Could it be that the heatsink block is sitting proud on something? Perhaps a thermal pad too thick?
