Hi all, so a bit of annoying problem started with my car today (’61 B7 Passat Sport 2.0 BM Estate).
Im working from home so car is used a few days a week for short journeys (I am smart charging once a month) but the car has sat for probably 3 or 4 days now doing nothing and this morning on what seems to be the coldest day ever I went outside and started her up, engine was running for a good 5 minutes or more whilst the heated windscreen and blowers were on but then as I put my foot down to drive off the drive, the ‘Error: ESP’ message came up on the MFD, the ABS light lit up yellow and the car completely cut out and lost power.
Silly me just thought it may have been a battery issue so restarted the car and drove off in hope it was a one off and something to do with the Baltic weather. However another 20 seconds down the road (at a roundabout, typical) the same happened again. I managed to start up again and get it to a safe place and left it as now it wasn’t going any further than a few yards without the error popping up and car just cutting out completely.
Thinking it may still be the battery, I went back home as luckily I had purchased a new one not so long ago (I was holding off fitting until the car was going to be used a bit more), admittedly it wasn’t fully charged but I checked it and I think it was around 12.4v so plenty enough, you’d think? Anyway, battery swapped over and issue still exists so I made use of my breakdown policy and got recovered back to home which was only a few minutes away. Didn’t want to be taking it to a garage with a blank cheque in hand straight away without having a look myself first as im quite handy and would like to try and fix myself. Im also in no rush to use the car anytime soon.
Having got it back home this is the way it plays out:
- Car will start at first push of the key, engine runs, all dash lights go out and all looks good, but within 10 seconds I see the DPF light quickly light up followed by the parking brake, the ESP error and the ESP/ABS light – all in yellow, not red, and all engine power is lost again.
- If I try to start the car again straight away, It wont turn over at all for another few minutes and then the same process happens
It certainly seems to be some electrical issue somewhere, just not sure where to start? Im taking the DPF light with a pinch of salt, along with the parking brake light as the brake works fine. Im also wondering if the EPS issue is also a red herring and that whatever electrical issue it is, is just causing random stuff to error?
Unfortunately I don’t own or have access to VCDS but I do have a Carista OBD device, read codes, cleared, started engine, read again and still getting a few that fall into the below.
- 01314 Engine Control Module (ECM) and shows under the ABS, Parking Brake, Power Steering, Central Electronics and CAN Network Gateway headings – once again not sure if this is just highlighting that these areas have errored rather than pointing to a specific issue?
- 68108 for both Driver and Front Passenger Door
Not sure how meaningful these are and if they are related:
- 12648480 – Parking/Steering Assist
- 13701376 – Heater + Air Conditioning
- 13639424 – Instrument Cluster
- 13639427 – Instrument Cluster
- 12648448 – Instrument Cluster
- 12658432 – Instrument Cluster
but decided to leave the old ecu on...been fine touch wood for 3 years...grrr now ive jinxed it .
