*** NVIDIA GEFORCE RTX 3080 SERIES STOCK SITUATION - NO COMPETITOR DISCUSSION ***
Queue Position of Asus GeForce RTX 3080 TUF Gaming 10GB GDDR6X PCI-Express Graphics Card
oimg
Full spreadsheet:
https://docs.google.com/spreadsheets/d/1fQ7GlVhIP_YNjFJQYFvE5a-6H1Ywnw7aacjRfLNn_tE/edit?usp=sharing
I’ve been in position 5 for ages and 5 cards due in, I’m now position 1!!! Where has the 5th card gone? This is ridiculous
Possible explanation.
@ScottiB
Sorry for bothering you but just a quick question. Do you know what happens to RMAs for the RTX 3080s in regards to the queing system? I understand if you aren't able to answer that but worth a shot eh?
Since those unfortunate customers have already had to do their waiting once we essentially we treat them as though they are at the front of the queue. We can't actually put them back into the queue at the front but they wait until the next batch comes in then we assign them a card from that. That's the main reason why there's occasionally a small disparity between what Gibbo says has arrived and how many queue slots are moved.
Thankfully, these cards seem to have a very low failure rate, so we don't have a big backlog of people waiting for replacements.
Queue Update on Strix 3080 OC.
23/10 - 1165
28/10 - 1110
06/11 - 1022
13/11 - 955
20/11 - 921
27/11 - 879
04/12 - 846
11/12 - 800
14/12 - 791
19/12 - 746
24/12 - 729
08/01 - 628
15/01 - 621
22/01 - 608
29/01 - 593
05/02 - 591
12/02 - 567
Probably an RMA for a duff card from somebody else who received theirs before you. It's unfortunate when that happens but these are electronic devices and can/do go wrong. The replacment would be fulfilled before those still waiting in the queue.
Has anyone had their card come with some of the packaging looking as if it had already been opened? Mine came in a box with asus tape over the top which looked normal, opened up and the main GPU box was also normal looking except the round sealing tape things on either end was only taped on one bit of the box, so it wasn't actually sealed. Antistatic bag looked normally sealed, though where the PCIE bracket is there was a small hole in it by the bit where you screw it onto your case. Don't think i did that as i was handling it fairly carefully.. All i can think of is that it was panic packaged at the factory?
I've tried putting some load on it and mining with it and it runs cool as a cucumber in performance mode, though my room is now too warm
my box was opend but the graphic card was sealed and i didnt know why.
That's crazy. Who knew few hours can make a huge difference. I ordered on 17th Sep at 14:27 and received the card on 5th Nov I think.
It's very strange as it looks like the number of cards received decreased not increased. It's like they're not producing them anymore lol.
i think it would depend on which card u have ordered.
Finally some movement in the Eagle queue!!!
I wouldn't get your hopes up. They haven't had any deliveries yet in 2021. I moved 244 to 242 this week, and the only movement is cancellations unfortunately.
This particular card seems to be the lowest priority for Gigabyte, as all their other models are being shipped, albeit in small quantities. It would be nice to get some clarification on why this is.
