Samsung WEA302i Default Login
15 Mar 2004
Oxford
Hello,
Not sure if anyone can help me.
I have an old Samsung WEA302i Wireless AP and i'd to use it to use at home.
But for the life of me i can't find the manual and need to login into it to change some settings.
I have tried the usual usernames and password of admin and admin but it doesn't accept it.
Does anybody have any idea ? Searching google returns nothing at all. Not even the manual says anything online just how to mount it to a wall.
Thanks
The product brochures seem to say that they will work standalone.
For the power supply, it's 802.3af PoE which is easy enough.
Did you factory reset it before trying with the guessed default credentials?
Not sure it'd be worth the effort for such an old AP even if you can work out what the username/password is.
I googled your exact thread title and this was the first result:
Default Login Credentials:
IP Address: 192.168.20.100
Login ID: root
Password: sweap12~
Mode: Access Point mode (L2)
SSID: SEC_WE_AP (Open mode)
I think i did.
i mean i held the button in on it with a paperclip for atleast 5 seconds lol
