I mean deaded, no way back, stick it in the oven and bake it, it still won't work. Complete irretrievable failure.What do you exactly mean when you say "died"? I bought a second hand 770 in december. That's a 8 year-old card. Didn't work, had overheating problems with it so the PC would shut down itself after a few seconds... All it needed was to be cleaned and to get the thermal paste changed... replacing the fans would be ideal, but I'm just using it while I try to get a new GPU from the 3000 series... I don't think it is easy at all to damage a GPU, at all, unless you do something you shoudln't be doing to it.
