PSU: is Corsair RM650 good enough for Ryzen 3900xt + Asus RTX 3070
15 Aug 2020
Hi guys,
I just upgraded my GPU to an ASUS RTX 3070 Dual OC and am wondering if I also need to change my PSU (Corsair RM650 80 Plus Gold). I ask because I saw on the Asus website that they recommend a 750w PSU for my system given I have a Ryzen 9 processor, otherwise 650w would be fine. I am also using a daisy chain cable from my PSU to the dual 8 pins to plug in my GPU to the PSU.. am thinking of changing that to 2 separate cables.
Specs below:
Ryzen 3900XT (will not overclock)
32gb Crucial Ballistix @ 3733 CL16 (66ns)
ASUS RTX 3070 DUAL OC (will not overclock)
Gigabyte Aorus Elite x570
Sabrent Rocket PCIe 4.0 SSD + Sabrent Rocket PCIe 3.0 SSD
NZXT Kraken x63
p.c. part picker estimates 460 watts for the above, and Newegg's PSU calculator estimates 489 watts -although I realise those aren't very helpful
Thanks
RTX 3070 is 200W
3900XT is 150W if you do all core OC
your system is probably another 100-120W
so should be sufficient to cover it. wouldnt be in the peak efficiency band of the PSU but you are not going to loose out much.
