Yes I believe it is, Amazon includes the VAT etc on screen so no hidden surprises.Is that VAT and import duty paid? If not you’ll be charged another £36-ish to get it from the courier company.
Openreach ECI 061513 (1b) or Huawei HG612 modem will work. Should be £10-£20 on the 'bay. Also Draytek Vigor 130 but that's £85 new so £40 used for no appreciable benefit.
You'll need your PPPoE login details from Vodafone if you don't already have them.
Can I just say thank you for this recommendation?
What else is wrong with it? Is it just the led that has become dim or were there other issues?Not happy with ubiquiti hardware. They cheaped out on my unifi ac pro. The blue led is barely visible after a year of running.
I got the Hono(u)r 3 router and it’s amazing for the price. Yes, there are better routers out there but not for anything close to the price I paid.
I paid £50 for a router that does what it says on the tin. Easy to use, far better networking than the potato BT sent me and just a great little deal.
I am thinking about buying a new router. I've just started to look in earnest.
I'm currently using an old Billion 7800n http://billion.uk.com/product/wireless/7800n.htm It's actually okay, but is starting to creak a little esp when streaming to two devices and the WiFi is a little patchy, which is annoying for my other half when she's zooming on the sofa, which happens to be a bit of a flaky patch.
We've got no WiFi6 devices though, I stream to the TV using a laptop which is ac/a/b/g/n, we use iphones (7 & 8) and iPads (mini 4 & Air 2) so all old kit really.
Is it likely we will we see any improvements with the Honour?
The link to the Huawei variant, same price, slightly higher spec hardware to the honor 3
https://consumer.huawei.com/uk/smart-home/ax3-quad-core/buy/
You would be buying a UK model from Huawei UK site there, so won't have the additional signal amplifiers of the Chinese model people talk about (I think, I don't actually know) but coverage is fine, obviously plenty of factors impact that so YMMV.
No manuals in the box Oddly but quite straight forward.
So the whole range is garbage because the LED failed? Makes senseJust the led thats gone really dim. Other than that its its s working fine
Pulled the trigger on it. Hopefully will keep my other half happy watching iPlayer whilst I watch the footy. Got plenty of broadband bandwidth but not so much on wifi.
we lost our line a couple of weeks ago, enclosure got damp and froze, you'd thing the world had ended.So the whole range is garbage because the LED failed? Makes sense
