Hello. I'm trying to decide on a bottom radiator for my O11D XL build. I understand that there should be plenty of space for a thick rad in pull, or even push/pull.
I'm especially curious about the medium thickness / high fpi vs thick / medium fpi comparison. I can only find general statements "high fpi needs high speed fans", etc. and no testing.
I'm planning to run fans at around 1,300 rpm for general use, at which I think it should be fairly quiet at the 3m or so from me the PC will usually sit.
I like the drain port location of the Thermaltake rads, but they're a relatively unknown quantity to me. The EK I guess is the safe option.
Any views on thickness/fpi and general brand quality appreciated. Details of the rads are:
TT CLD360
https://uk.thermaltake.com/pacific-cld-360-radiator.html
406(L) x 119 (W) x 40(H) mm
25f pi
1,000g
TT CL360
https://uk.thermaltake.com/pacific-cl360-radiator.html
405 (L) x 132 (W) x 64 (H)
14 fpi
1,658g
EK XE360
https://www.ekwb.com/shop/ek-coolstream-xe-360-triple-5419
18 fpi
2,050g
TT CLD360
25f pi
1,000g
TT CL360
14 fpi
1,658g
EK XE360
18 fpi
2,050g
