My sink tap has started to drip - It is 10 yrs old so I accept that- Oh - I cannot shift the chrome bits that cover the tap valves.
Started searching for a new mixer tap and found what we wanted -slightly bigger than existing - Bought that.
Next job was to have a look under the sink
Most people can probably guess what it's like - Started poking things and found the two isolators Hot and cold and the sink waste pipe is directly in front of hot isolator. The cold one is directly behind sink bottle trap. Taking off waste pipe I found the isolators siezed solid and could see a label on them "Jacko's second hand isolaters" - - One of the pipes was covering outside tap isolater. One major problem is hot water pipe does not have a drain valve and when I drain it down there will be at least 2ft of water in upright pipe below isolator valve so its drill a hole time.
In short it is a right mess - So got some flexi pipes and two new isolator with handle on - a drain valve and dug out some old copper pipe and spent a rather tense afternoon fixing up a new bit of pipe for when I take the old lot out.
It should be much neater and it should work fine -I hope !
Tomorrow is launch day - Wife is going out despite the lockdown as she said I am not staying in when you do that job.
Rant over - feel a bit calmer now
Most people can probably guess what it's like - Started poking things and found the two isolators Hot and cold and the sink waste pipe is directly in front of hot isolator. The cold one is directly behind sink bottle trap. Taking off waste pipe I found the isolators siezed solid and could see a label on them "Jacko's second hand isolaters" - - One of the pipes was covering outside tap isolater. One major problem is hot water pipe does not have a drain valve and when I drain it down there will be at least 2ft of water in upright pipe below isolator valve so its drill a hole time.In short it is a right mess - So got some flexi pipes and two new isolator with handle on - a drain valve and dug out some old copper pipe and spent a rather tense afternoon fixing up a new bit of pipe for when I take the old lot out.
. My jobs always take longer. I chose the change my tap a couple of years ago and found the new tap was slightly too big for the hole
, so I had to file it out and the sink was resin so blunted my file
