Should I upgrade from my MacBook Pro?
14 Sep 2014
So I have a 2012 Retina MacBook Pro 15" and I was wondering if I should upgrade from it? I mostly use it for writing, social media and watching Netflix or YouTube. I replaced the ageing battery last year, and it seems to be working fine without any issues, but it's still a 9-year old machine.
Any thoughts? Here are the specs for my MacBook Pro
CPU: I7-3615QM @ 2.3 GHz
GPU: NVIDIA GeForce GT 650M 1 GB
RAM: 8 GB
SSD: 256GB
Battery cycle: 220
Thanks
13 Jun 2007
London
Whilst your usage requirements definitely do not require an upgrade, the new M1 Macs would wipe the floor with it. Especially with battery life.
Another thing to consider is that your model does not support the latest version of macOS. Again, not necessarily an issue.
I have hovered over the buy button for a new Mac since the M1s launched but the more I think about it is my 2015 rMBP is still just fine. The only thing it suffers from is reduced battery life but I have other Macs for work so it's never an issue.
3 Jun 2005
The South
Along the same lines as @Feek - save the pennies for when you actually need to upgrade, especially as Apple Silicon systems will only continue to improve.
Plus you can upgrade the ram and hdd on the 2012 15@ MBP, so you can always eek out a bit more performance.
9 Apr 2008
Bedford
I had that exact Mac book pro till last April, honestly the only thing I found it struggled with was Civ6 when they released the New Frontier Pass. Everything else I needed it for was easily handled, I did find avoiding the update to the first os that used metal helped with its performance but again probably Civ related.
My little sister is now the owner of my old MacBook Pro and is getting plenty of milage out of it with a similar usage and it sounds like you're in the same sort of boat, you might as well enjoy the 15 inch screen and all the other mbp benefits until it can't go on then look at your options when they do an ARM 16 inch mbp.
25 Aug 2008
1) Why did you start this thread - you are clearly thinking about it, but does your MacBook not do anything you want it to do?
2) Do you have everything on it backed up?
13 Jun 2007
London
And just like that, my old 2015 Mac has started powering off randomly, I suspect the battery is on the way out
