Except it isn't really - unless they are noticeable cheaper than the equivalent geforce then miners will continue to but geforces that have guaranteed resell value
They can't nerf existing cards because people have already paid for them.
Just think of the court cases if Nvidia gimped cards which people already own... It would be highly illegal
Like I said, existing cards aren't affected, only unreleased products.
Yes, but people keep whining and saying that they should do it for existing cards... I was just pointing out why they can't
if it a driver they can do it for all cards if they want to, your performance isn't gone you can just use an old driver no one forces you to upgrade driver and Nvidia doesn't have to give you a driver - I've never seen anything in a review or advertising saying "you will get 1 year driver updates from Nvidia for this"
Still a very dodgy position for Nvidia to take and i doubt they would want to invite the inevitable legal challenges. It isn't worth it.
Doing it at the aib vbios level would be great then, all new cards = nerfed, all existing cards = high hash rate. Miners can play pass the hot potatoe for all existing cards on the market and gamers can get new cards without having to fight with miners
I expect we're going to have several cycles of new PoW coins being "invented", inflated briefly because they're profitable to mine and trade, then dumped/deflated. And crucially there needs to be more evidence that these investments can lose money. Enough that the "get-rich-quick" brigade lose some confidence in them.I don't think the GPU mining craze will just go away / cease with the transition to Ethereum phase 1.5/2, or government regulation - In this instance, a cryptocurrency will still be able to prosper in countries where there are no cryptocurrency regulations.
There's also Ethereum Classic, which will carry on using the a similar Proof-of-Work algorithm called Etchash (used by Ethereum GPU miners currently), but at a less profitable rate at this time.
Then there's a another proof of work based cryptocurrency called Conflux, which uses an algorithm called Octopus for GPU mining. This one appears to be more profitable for Nvidia GPU miners, than mining Ethereum Classic would be, here we can see possible GPU mining profitability on different mining algorithms:
https://whattomine.com/gpus
The Conflux GPU mining profits appear to be only be a bit lower than mining Ethereum.
So, I hope these facts won't go unnoticed by AMD and Nvidia, and they don't just hope the high demand problem (which is partly a result of GPU miners buying graphics cards in bulk) will resolve itself...
Anything in software can be defeated. Firmware is a little more tricky. But...Well they would have to lock the vbios or people could just bios flash over it
Except it isn't really - unless they are noticeable cheaper than the equivalent geforce then miners will continue to buy geforces that have guaranteed resell value
