Also amusing when you then see Americans who think we're mental for going as far as 10,000 miles without an oil change, whilst they're changing their oil as often as they fill with fuel*
*may not be entirely accurate
AAA:
I'd only be comfortable staying on 2yr/18k if all the journeys making up the lower mileage were still long individually - based on VWs advice (my car being a Skoda) that such a schedule is aimed at people doing predominantly long journeys, fully warmed up, not pushing the car hard etc.
My M3 is on 2year intervalsChange oil and filter every year, dont go by the 2 year thing. Unless you dont care about the car and arent keeping it long term ofc.
Sure mate...The issue is that changing oil every 2 years is okay as it won't start causing issues until it's older than 6 years and possibly a lot longer than that.
By then it's out of warranty and been sold on by the original owner from new. So the manufacturer don't really care if it lasts 8 years or 30.
So they don't care about it lasting any longer than 6 years until their original customer has sold it on and it's no longer under warranty. Until then they recommend the bare minimum to get it to the point it's no longer their problem if something goes wrong.
Change the oil every year and yeah it will prolong the life of the engine exponentially along with other regular maintenance and servicing.
So it entirely depends on how long your planning on keeping it for. If you bought a brand new M3 and plan on keeping it for 15 years then yeah get the oil changed every year. If you bought a brand new M3 and plan on keeping it for less than 5 years then just stick to what they recommend.
What makes a year magically okay? Why not once a month?
.Seems there is a lot of experts in here, I guess I should ignore Castrol and Ford and trust them.My thought as well. Who needs oil analysis when you can use a kitchen towel and a colour chart.
Even if it's due at less than a year, that sounds like a stupid way of timing your services.It gets done annually regardless of whether it's due or not.
I wrote that in haste and perhaps worded it incorrectly, if something is due earlier then of course it gets done. On the other hand however I would never run my car for 2 years without servicing even if the handbook said to do so.Even if it's due at less than a year, that sounds like a stupid way of timing your services.
