Android 12 Developer Preview/Beta Thread
V_R
V_R
17 Jan 2007
UK
https://developer.android.com/about/versions/12
Looks like we'll get 4 beta releases this year starting in May.
Just loaded it on my Pixel 3XL. First impressions is it's slower than Android 11 (for me)
Not too much looks different apart from icons are way oversized now.
I've just changed my background to a stock photo that's mostly orange as I thought all the accents would change, like in the quick settings, but everything is still blue.
Isn't it meant to do it by itself? I did it manually which looks better but one big annoyance is the clock on the lock screen is still blue, and not orange - Reboot didn't fix either.
Sure I only just installed 11 beta....:confused:
*ah, no, it says android 11 but the build number is for 12 beta 2
Been working fine for me.
I installed the beta on my Pixel 4XL earlier and then removed it again! Loads of apps kept crashing - GMail, Santander, Virgin Money, My EE - apps I use pretty much everyday. So will wait for a final version before installing again.
Trying Beta 4 on my Pixel 3 XL second phone, did a clean wipe, not bad at all, quite smooth.
Nothing has crashed. Used NFC , android auto etc. all good.
Also on a Pixel 3 XL, been on since Beta 1, getting better every release. This one however, toast notifications get stuck and don't come all the way down. No Biggie.
