Looking for a new wireless headset, £100 or a little more.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Current one is a Corseair HS70, which i'm not impressed with and has developed a fault, for one its falling apart and if you mute the mic sound goes off completely, Windows sounds.. everything, you have to pull out and put back the wireless dongle to get the sound back.
Which purpose? PC or a Console? I have Penrose and they sound great. I sent the Arctis straight back...the build just didn't look sturdy enough and I'd read about the issues with premature breakage of the hinges. I knew audio better on the Penrose
I’m in the same boat currently have a cabled cloudX set but would like wireless
What did you opt for in the end?
Or any other opinions up to £100
Thanks.
Thanks.
Arctic Liquid Freezer II 360 :D
I haven't yet, after kicking it around the room for a while it appears to be working again tho its still on my shopping list, i have narrowed it down to either Roccat Elo 7.1 Air or if i'm more flush SteelSeries Arctis 7.
Edit: i already said that. i honestly don't know, it will probably be the SteelSeries Arctis 7 because you do pay for what you get, i know people with SteelSeries Head Sets, they are good, currently £135 on a large well know Online Store.
Ha! Will take a look ;)
What did you end up buying?
I missed this thread back in Feb or i would have said avoid the roccat..
Pain in the butt for me.
