You can actually mine Raven coin with them ...They were all snapped up again 2mins into sell time, and you can't mine with them so all those bs mining conspiracy theories can go out the door.
massively overpriced crap...£400-£500 for a 2060s basically - insane.
eth miners cant use it anyway or rather it is crippled.
I think scalpers are more to blame than miners tbh and low supply ...Bs mining theories? Think you might need to look around at some pics doing the rounds.
I don’t know which review site you are in reference to but kitguru has done a fairly thorough review.
3060 is slower than 2070s. It’s performance is on par with 2060s and 5700XT. It is not 50% faster than 2060. At best 10% average. Very underwhelming tbh especially considering it’s current pricing.
Doesnt take away from the fact that 3060 is a garbage SKU from the 30 series. The only thing got going for it is the 12GB vram which may future proof it a bit better with the more complex shader packs.
it is completely in the opposite direction of all the 30 series cards in term of performance.
3060ti is just above 2080s
3070 is like 2080ti level
3080 is a generation jump against 2080ti
this card should be like 2070s or better
I expect 3050 or something like that with 6GB vram to be like 2060s performance but at £200 MSRP mark.
Both companies have figured that if you completely stagnate the mid-range, a lot of people will just jump up to a higher SKU in the range to get their upgrade fix.It performs more like a 3050ti than a 3060. The gap between the 3060ti and 3060 is too big
Hence the mid-range barely moving in years and years. And when it does move a little, the price shoots up. So now we have £500+ x60 Tis and £400+ x60s. Ignoring the fake-as-hell RRPs which AIBs can't realistically sell at.
The £200 price range has basically ceased to exist..
I have just gone through all their bench with the MSI Gaming X Trio.Guru3d review shows 1080p performance approx 30-50% more than 2060S across the board.
Slightly less gap at 1440p but still ~35% or so more
But isn't part of that because millions of chips are being diverted to large mining operations before they even enter the supply chain?Its not miners or scalpers. When retailers receive a total of 100-200 cards its just low supply issue. If each retailer received 1 million plus units then it be a different story.
doubt they are even made in the millions.But isn't part of that because millions of chips are being diverted to large mining operations before they even enter the supply chain?
