Good afternoon,
I've had the Gigabite Aorus 3080 master for about two months and no issues at all. This morning I went on the computer for a hour, switched off, went to work. When I got home, turned the system on and no display. When I open the case there is power going through the card, the gimmicky LED display is still powered/working, but no display. I've changed monitors, cables, bios reset, software removed/reinstalled but still no display. I've taken the card out and put my old one in and the system works fine. Does anyone have any suggestions?
My system is:-
Team Group Dark T-Force 32GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit
MSI B450 TOMAHAWK (Socket AM4) DDR4 ATX Motherboard
AMD Ryzen 5 Six Core 2600X 4.20GHz (Socket AM4) Processor
CoolerMaster MasterBox MB500 Midi Tower Case - Black
Bitfenix Formula Series 750W 80 Plus Gold Power Supply
Seagate 2TB BarraCuda 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008)
Gigabyte UD Pro 512GB SSD 2.5" SATA 6Gbps Toshiba 3D NAND Solid State Drive
WD blue SN550 1TB
Thanks
My system is:-
WD blue SN550 1TB
Thanks
