Hi I am looking to upgrade my workstation.
My current setup is
i5 4670K 3.4GHz (4 cores, 4 threads)
GB Z97X-UD5H Motherboard
32GB G Skill DDR3 2400Mhz
ATI Radeon 512MB HD 4800 Series Graphics Card.
I don't really tend to play games but I do a lot of processing and run virtual machines.
I wondering if I should look to with AMD or Intel?
Some of the AMD processors look ok but they all appear to be orientated towards Gamers and I need something that supports most of the common CPU instruction sets.
I was thinking about sticking with Intel and go along the lines of an i9 with around 10 cores?
Then I will need a semi decent Motherboard to go with it and around 32-64GB RAM.
I'm not too bothered about a graphics card and can stick with what I have because my monitors can only support 1080P HD.
Please can someone recommend something.
Thanks
My current setup is
Thanks
