I am trying to put some context into what this car actually is though, while it is now a car of little value, it is only this context which makes those numbers look larger. The car was a much more expensive car and in this context the parts are perfectly reasonable.They might not be big numbers to you but then you don't have a car budget of £2k either do you?
This doesn’t make it a bad purchase, but you really must consider that you are buying into an expensive car for not much money, rather than buying a cheap car...
I am trying to put an alternative view to this thing, as it could be quite a nice car for £2k..
