In terms of your sources being out. I've no idea on specifics of the flux but you need to ride it for 10+ mins, then do a calibration on both the trainer and the PWM. Then do a dual recording of some kind. It's all about proper calibration.
Sorry to say it, but 4iii for the majority of cases is a random number generator. They are ****. There are some good ones, I have a mate who has one that tracks well but for the most part in what I see on those single sided things is they are cheap for a reason and that's because they're mostly terrible.
I've not found them terrible, but with the trainer issues I've had probably related to cold weather was just after something to give me some consistency. Can't justify changing the Trainer at this point (due to price & availability still a shocker), but S/H PWM prices have not had the hike that most other components seem to be seeing. I figured it was an easy choice to spend ~£200 now for 'ease' on something until I can get the trainer more reliable, then could sell the Stages on. But in reality with Operation New Bike, delayed but firmly in the planning stage until the market recovers it would get used there. Or continue life on the Turbo bike. Could always sell it in a few years time and not lose much on it.
First comparison from the long endurance race saturday. Cold start and Flux over-reading slightly -
https://www.zwiftpower.com/analysis.php?set_id=123825
No calibrations that time. 4iiii
TTT with calibrations on the 4iiii. Bit warmer but you can see they're tracking much closer -
https://www.zwiftpower.com/analysis.php?set_id=123857
Spinning around with the new Stages, couple of calibrations. Tracking similar but slightly higher, but think that it was colder in the garage -
https://www.zwiftpower.com/analysis.php?set_id=123860
Mostly tempo, couple of climb efforts and then a 3 minute effort at 36 mins. Steady state it seems accurate, but on the climb efforts the Flux really under-reads by a good 50W+. The 3 minute threshold/FTP type effort it's 10-12W out on the average (so well within margins).
Flux vs Stages: 1st climb -65W avg over 60s. 2nd -5W avg over 2m30s. 3rd -30W over 30s.
Calibrated.
Tempo -38W over 4 mins. 1st climb -3W over 2m30s. 2nd -20W over 32s. 3rd -5W over 2m42s.
So it seemed to settle down after that initial 4 minutes off. Harder sustained threshold/SST seems to be better.
Shorter efforts/sprints/standing push it off, but the peak from the PWM 1s-5s power is around 100W higher than the turbo, so compensating for that really probably pushes the average out on those short efforts. See the same with the 4iiii though.
Flatter TTT course tonight with a couple of longer climbs in there. With a very fast group so I'm going to be at my absolute limit hanging on them. We'll see what the numbers show as I'll dual record that too.
I bet you have a saddle bag on too!
No! But do have a clip on there so I could switch my bag over as required.
I do have a mudguard fittings on there though!
