Spare PC won't power on at all
17 Feb 2009
Put together a PC with some old parts I have, and for some reason it won't even power on ?
I have no HDD, RAM, GPU or CPU connected to it, although I tried with a CPU in and still nothing.
The PSU is hooked up to the mobo ( 24pin ) and cpu socket.
Also the PWR switch cables are connected correctly too
When I connect the AC cable into the PSU and press the on button nothing happens
As far as I know all the parts are in full working order as it's mainly stuff from my old PC
Neither does my crystal ball power up, so what's the part list?
As for causes could be dead "BIOS" battery, old PSU having gone permanently cold etc...
A320-MH Mobo
CoolerMaster Masterwatt Lite 500w
Three case fans
AMD wraith stealth cooler
Just tried a CMOS battery from another old PC and no luck. Must be the PSU. Really odd, it's never been dropped or exposed to water. And last time I used it it worked fine
You have no RAM in, but expect it to power on?
Moving to the obvious, have you tried just testing the PSU on it's own? Take it out the case, disconnect it from all the parts and short PS_ON (Green wire) and one of the GND (Black ground), you can use a piece of wire, or solder, or even a paperclip straightened out.
I'd rather leave it to be honest, don't want to mess with a 500w PSU.
Even without RAM it should at least power on and get to the BIOS.
No.
If you are local to me feel free to drop it round and I'll diagnose it and finish building it for you FOC. :)
Right.
I got an old old motherboard from 2009. Connected the 24-pin into it, then powered up the system and low and behold it powered up.
Must be a faulty mobo then !
Don't be so quick to jump to conclusions, as it sounds like you have very little knowledge of PC building and diagnostics.
Firstly a PC will not past POST and be able to enter the BIOS with no RAM installed, secondly you could have something as simple as a short to ground in the motherboard to the case.
I know that. What i'm saying is all I want it to do is power up. It powers up with an ancient dell mobo but not with the gigabyte A320.
I'm new to building PC's but I know how to put one together
In that case. Should I take the mobo out the case and see if it powers?
It is a good idea to check this, yes.
I would have only the CPU, and one RAM module installed (in the slot it advises you in the manual), no HDD/SSD etc. and as you are running a 2400G no need for a graphics card either. Pop it on a card board box, and just connect the 24 (or 20+4 pin) and the 4-pin (or 8-pin EPS) to the CPU power and then short the pins on the board for Power on the motherboard header.
Are you sure you've wired up the power button correctly? I've been caught out by that a couple of times.
Also check you've connected the 8 pin power connector to your mobo too.
The CPU cable ?
I connected the 24pin to an old mobo and it switched on fine.
It could be a problem with the switch on the case itself ? No idea.
I tried the pwr switch many different orientations, no luck
