IS THIS GAMING PC ANY GOOD
6 Mar 2021
i3 9100f
8gb ram DDR4-2400
Rx 570 4gb
480gb ssd nand m.2
B360M-HDV matx
This is all the info they provided im not much of a pc genius so was wondering if this pc is worth it for 550$ plus some other accesories
6 Nov 2005
The GPU is fine for most 1080p gaming, cpu is only 4 threads which isn't great and can cause slow downs in some games, and 8 gb ram is the absolute minimum for gaming. Unfortunately with the market the way it is currently the price is probably just about right. Its fine, but not great
2 Jul 2019
Pass. Despite the above being correct i just don't think i could pay 550 for a machine that was worth £300 max 6 months ago, and likely less in 6/12 months.
9100f is a bit slow these days, adequate and good little CPU, but ultimately struggling in multicore games. 570 is decent enough, but will show it age very quickly with more recent games as it's on its last legs.
OP
6 Mar 2021
Z67x gigabyte motherboard with optical audio
Intel i7 2600k 3.5ghz 3.8ghz turbo
8gb dual channel corsair vengence
Gigabyte g1 gaming gtx 970 4gb
128gb ssd
500hdd
New 550w power supply
Z97 gigabyte motherboard
Intel i5 4590 3.3ghz 3.7ghz turbo
8gb hyper x dual channel ram
1tb hdd
If anyone doesn't mind which pc would be the better choice both are 600 AUS dollars
9 Jan 2016
Derbyshire
the first one is still very capable of gaming, a quad is a quad and will always be better than a dual core, so no matter how many threads it has it will still hold up in gaming as specs of games tend to require a quad even as a minimum. 570 is a beast of a card in its own right, however depending on your game and res the 4gb vram will be limited.
current prices its good enough deal, if you can knock the price down then even better.
2 Jul 2019
It's not - it's £397.40 you haven't done the conversion. :p I would say that was nearly worth it. Maybe $484.40 I would pay which is £350.
It's AUS dollars now :p
OP i'd ask in an Aussy forum as GPU prices are all over the place right now. Hard for us to say what's worth it in terms of money/value.
