i have one issue with the k95 platinum double clicks problems/
19 Jan 2021
i have one issue with the k95 platinum i am using the brown keys
my issue is that when i am typing some leters are double
why>> can you tell me the reasons please/?
why in most sentenses when i am typing i have double clicks
example
my namme is jim and i amm from greece
what causes this problem??
i have to clean my keybaord 1 year..
is it cause this problem??
can you help me please??
how i can solve this problem which i have with my k95 platinum??
in the first year when i bought the k95 i didnt have problems with double clicks
the problems started after 1 year and half..
i dont believe that my keyboard have tecnical issues..
It's a very common problem with Corsair boards. I had 2 K65s do the same thing and multiple other people in the ucuk discord have also. I RMA'd twice and didn't even unbox the 3rd one.
If you go to the RMA section of their website, there's a check box for the being the issue you're having. That makes it clear it's common imo.
do you believe that because i have to clean it 1 year that causes this double clicks??
Nah. I don't know if the firmware is running the debounce on the switches too low, or if it's bad switches but if you google Corsair keyboard chattering you'll see it's plenty common.
