- 30 Jul 2006
I have an ancient, noisy extractor fan in the bathroom which is controlled by a pull switch.
It is fed by four wires (Earth, Neutral, Live and Switched Live).
If you pull the cord twice to turn it on and immediately off again the fan carries on running for a while - which is good.
However, if you forget to pull the cord a second time it (understandably) keeps on running which is not so good (with apologies to the Spencer Davis Group).
There is a small (almost invisible) light on the front that tells you that the fan is running (just in case you are deaf).
I know that the correct solution is to have a ceiling light that comes on when the cord is pulled the first time and goes off when you pull the cord second time but I would really like to install an extractor fan that includes such a light - any suggestions?
