I was looking to get a 4k monitor for my home office for the work and photo editing real estate (and to play some older games at higher resolutions as a bonus) and while doing a bit of research I noticed the Samsung LU28R55 with the following specs: https://displaysolutions.samsung.com/monitor/detail/1532/U28R55
Seeing there was stock at my local shopping centre, I ran there, grabbed one and ran back. Got it set up and turned on, tweaked some basic settings and I have to say I am quite impressed. Bear in mind I have done no advanced dialling in of settings, but so far:
I will play around tonight and try some Skyrim for a laugh and watch as my 1660 Super cries. First impressions are decent though, considering I kept my expectations suitably moderate.
- 28"
- 4k UHD (3840x2160)
- IPS Innolux M280DCA-E3B AAS (Azimuthal Anchoring Switch) https://www.panelook.com/M280DCA-E3B_Innolux_28.0_LCM_overview_42094.html
- 1000:1
- 300 cd/m2
- 60hz
- Freesync
- 90% DCI-P3 gamut
- IPS glow seems no worse than my Dell U2515H, likely better.
- I have not noticed any major bleed so far and had a quick check in a dark room. Panel seems pretty uniform from my initial inspection, all things considered.
- Black levels are acceptable, fired up a quick game (Empire at war in a space skirmish battle) and I could see some surprisingly decent detail in the void though obviously nothing stellar (pun unavoidable).
- Colours seem ok without spending more time tweaking, though I still have work to do here when I find some good calibration guide. I am not expecting miracles at this price range and am buying this to tide me over until OLED.
- I was able to OC the refresh rate to 75hz straight away... 80hz failed though. I call that a decent result for a budget 4k screen! EDIT - Now down to 65hz as 70-80 gives aetifacts.
- It is not height adjustable but I knew this. The default height is fine and my head is centred so it's not a problem.
