So I was looking at how to undervolt the Ryzen series and it seems like it can be a bit of a pain in the ass and can eliminate your boost stuff, so you get better economy but wrecks your peak performance.
Then I find a video showcasing PBO2, basically a BIOS option that can allow you to optimise your power curve but done by the system rather than you, thus keeping the boost potential.
What I found amazing that under no load you get less heat and draw, yet under load, due to the power cap being the same the curve just lowered, it optimises the frequency x voltage. Guy showed it topped out at about .2gz higher clocks on the same volts and temps. On single core it got similar boosts yet 7c lower temps. Which is amazing. I know this info is vague, but it's not what I'm here for.
He stated his brand new ASUS 570 (insert long as name for top of the line here) mobo did yet have the BIOS update to allow for PBO2, Yet one of the similar MSI boards did have that update.
My questions are:
1. I'm getting the R7 5800H 3070 A15 Tuf Dash, is there any way to find out if PBO2 is compatible with that mobo?
2. If it isn't yet, is there a way to find out if they will be rolling out that BIOS update and will it be throught windows or a reflash?
3. Where does that stand in terms of warranty, because the user is not overclocking the chip, you're optimising the power curve and the software basically uses everything at it's disposal all on its own?
My questions are:
