- 6 Jan 2012
CP2077 loves cores! Thats why 5950x is almost 50% faster than 5600x at 1080p. Similar story with Intel.
It's impressive alright.
That said I mentioned it as SC is one of the few games I'm aware of that can and will use pretty much everything available to it. Which of course isn't to say it wont run decently on lesser hardware, but it does scale exceedingly well from what I remember seeing over the past couple of years.
Oh yeah, i've seem people get full core scaling on 16 core 32 thread Ryzen's, its the future....
Agree, but I am biasedI still think the 10850K is a fantastic buy
lol.
LOL
Agree, but I am biasedlol.
10 cores rumbling away at 5.2ghz is rather good for the cash. Even the AMD hardcore fundamentalists might concur?
Who am I trying to kidLOL
It was an agonising choice as I built the i9 rig about a week before Zen 3 came out. No complaints though, particularly as i got the willy wonka 3080 golden ticketThe 10850K / 10900K are good CPU's yes.
And a really good CPU facing stiff competition from another can only be a good thing, the CPU landscape is in a good place right now.
It was an agonising choice as I built the i9 rig about a week before Zen 3 came out. No complaints though, particularly as i got the willy wonka 3080 golden ticket![]()
I upgraded to a 5800X as I already had the AM4 board and while it's a good CPU if I was upgrading from scratch right now I'd probably go Intel i7/9 + Z490 since you get a couple of extra cores for the same price as AMD which makes it more futureproof for gaming although you would lose stuff like PCIe gen 4.0 but this won't be needed for gaming yet and by the time it is the CPUs will be to slow to make use of the extra bandwidth anyway.
Hard to say but pcie 3.0 is 10 years old! Not sure if us lot with Z490 'pcie 4.0 ready' will make the jump to 11xxx for marginal fps gains but some might?Will it matter in a year or two?
The 1% difference you're talking about would likely flip the opposite way and further extend in a few of years by having a couple of extra cores and while you could upgrade to a 12/16 on AMD these will likely remain expensive and will still be easily beaten by newer CPUs with less cores for the a similar price making a future upgrade not cost effective.I do not agree with this.
@humbug already presented information regarding Ryzen 5x00 series CPU's having massive headroom. Even that aside, when we look at PCI-E 3.0 vs 4.0 there's already an (albeit) slight difference.
https://www.techspot.com/review/2104-pcie4-vs-pcie3-gpu-performance/
Will it matter in a year or two? Probably not, but we have people including the OP who keep their processors for a half decade or more given the chance, and at that point the differences are going to be far more noticeable.
The 1% difference you're talking about would likely flip the opposite way and further extend in a few of years by having a couple of extra cores and while you could upgrade to a 12/16 on AMD these will likely remain expensive and will still be easily beaten by newer CPUs with less cores for the a similar price.
Most of the differences were from PCIe gen 3 running at X8 and while there was the odd game that was worse on 3x16 that's probably more down to poor coding of the game rather than anything else.If you read the review there's a 6% + difference at times with current hardware. I'm not convinced the extra core count will make as much of a difference beyond octa-core setups, although as you've said yourself AMD has the option to surpass that. I've seen 3900's for under £300 for example, high value second hand markets for CPU's are Intel's domain. You have to remember that outside of aforementioned outliers (Star Citizen) most games are designed for the lowest common denominator, being consoles. Current consoles even have tiers, but they're essentially 8c/16t AMD APU's that are slower than a 3700X.
The 5900/5950X will hold their price more since they are the last CPUs of the platform and given that they are hardly even available right now 4 months after launch I doubt there will be a huge stock of these as second hand parts.
while you can get a 3900X for £300 it's already beaten in games by a 5600X for around the same price and that's only in 1 generation.
That's may have been the case in the past as most people brought Intel but now AMD is hugely outselling Intel so in the next few years there will be a lot of demand for AM4 CPUs especially the 5000 series which will be the best upgrade available to many people who have AM4 boards but are running older CPUs.holding greater value is supposition, ultimately Intel is more popular than AMD even when AMD has the better product. It's the reason we regularly see Skylake quads go for silly money (I saw a 7700K second hand combo with a mobo go for £350 not that long ago).
For your third point, I agree that in current games the 5600X is usually better. However, your primary point was that a 10 core Intel was a better buy than an 8 core AMD in the long run. That's observably false, both I and @humbug have presented reasoning for this.
There absolutely is a noticeable difference right now between PCI-E 3.0 and 4.0 depending on the game, in large for the reasons mentioned by @turbot1984. That is only going to increase, and while "minor" right now it will not be for those that buy for longevity in a couple of generations. It's easy to say 6% is nothing (and I've seen other tests which give larger benefits, but I decided to link something easier to stomach) right now, but that 6% could well be 30% with the same platforms in half a decade. A difference where the limiting factor may well not be the CPU.
10 core Intel vs 8 core AMD performs about the same so matters very little right now but if a game can take advantage of extra cores in the future then it will favour the CPU with extra cores.
Even if it is 30% deficit in 5 year which I doubt very much it will be have you seen the results when trying to run a RTX3090 with a 5 year old CPU? So makes absolutely no sense buying a top end GPU to run on an aging platform.
