Socket A Duron Build Help
10 Apr 2015
Hungerford, UK, Earth
so put the basics of my retro PC in case, motherboard , cpu, memory and GPU. I have setup all the jumpers correctly and i get a single long beep, pause then single long beep, and repeat. Is this a faulty or incompatible memory module. its a single DDR 512mb
Caporegime
26 Aug 2003
Leafy Cheshire
Well, for starters that’s an SDR motherboard, not DDR, so I hope you haven’t forced a stick of DDR in there :p
Second, have you tried all the slots?
Thirdly, do you have any other sticks to test? SDRAM is getting old, I’ve got numerous sticks that have seemingly stopped working.
Also, you have cleared the CMOS I assume?
EDIT: Also that looks like a rather modern PSU. Slot A and Socket A were heavy on the 5v rail, is your modern PSU that is undoubtedly aimed at high 12v load able to sustain a high amperage on the 5v rail?
OP
10 Apr 2015
Incorrect its both types.. 2x SDR 2x DDR
i have tried both slots
i have cleared CMOS
re PSU yes modern and no idea lol
GeX
GeX
17 Dec 2002
Manchester
I have a Socket A board (Abit KR7A) that wouldn't boot using my modern PSU (Corsair RMI650 so plenty powerful enough). It has no -5v, but this shouldn't matter. I was going to try putting some 12v load on it to see if that helps.
It booted fine on an old PSU though
OP
10 Apr 2015
yeah i think i will get a an evercase one , ive ordered more ram anywa as its only £2 lol
28 Jul 2003
Dundee
Probably the size of the memory is the issue at a guess. I can't say I've seen 512MB as a single stick in those era of computers, most was 256MB in multiples
