Case needed for a 3090
19 Oct 2010
Hi
I've secured a 3090 and realised i'm going to need a bigger case to put it in. Is there anything I need to look for on the case dimensions to ensure it will fit?
I'm probably going to do an RGB build but with just a grey / back / smokey white theme.
Help.
Thank you.
Are you after an ATX, M-ATX, or ITX case?
What's your budget?
Do you want RGB or would you rather have a windowless case?
Is noise a concern?
I would recommend going for something mesh-fronted to ensure good airflow, here's a few of options for you:
My basket at Overclockers UK:
Total: £724.14 (includes shipping: £47.28)
All of the above can be found in both black and white versions, you may want to add to or flat our replace the fans depending on your needs.
Thanks for the suggestions, i'm going for the Lancool II Mesh.
Edit. Whoop Whoop. I can reply, sorry as a "new user" I was in forum prison for 24h as i'd posted more than 15 times in 24h. Ha
